TRB140 Mail not working
Dear all,
We recently purchased a TRB140 device to use with the SMS2Mail functionality. Today, I finally had the chance to insert the SIM card and properly set everything up.
However, I’m currently facing an issue with configuring the email settings. I’m not using a Google server, but rather one provided by GWDG. I also tested it with my own Mailcow server, but in both cases, I only receive a “NOOP” response and no emails are sent.
The device is running firmware version TRB1_R_00.07.15.2, and the WAN interface is set as the default route.
Could you please assist with resolving this issue?
Best reagards,
Hagen
Sounds like a configuration issue, could you please share your configuration under System → Administration → Recipients?
Please blur out email addresses, passwords and such.
Additionally, I found these SMTP settings for GWDG: https://docs.gwdg.de/doku.php?id=en:services:email_collaboration:email_service:pop3_und_imap
Check if yours match.
Hello MastasR,
thanks for reply. The settings are match how I can see that or do I need to use POP3S or IMAPS?
Here are my configuration for the mail.
Thanks a lot and kind regards,
Hagen
Hmm.. Settings look to be correct. I’d like to view the logs, and for that I’d like to continue our conversation in private. I’ve sent you a form to fill out to avoid accidentally leaking any sensitive information. In the Ticket ID field, simply enter the thread’s number, which is 14463.
Thank you for your help. What should I enter in the Ticket Description field?
Usually it would be the description of the issue that you’re experiencing, so you can just copy & paste what you wrote in your initial post.
