We have following problem with some of our TRB140 modules:
For some modules the update fails either via webinterface or via commandline/sysupgrade. Within the webinterface there is no errormessage displayed but after rebooting, the system still has the old firmware installed. When upgrading via sysupgrade we get some more information - we think it has something to do with one of the “mods” listed below:
root@Teltonika-TRB140:~# sysupgrade -n -v /tmp/TRB1_R_00.07.05.4_WEBUI.bin
Tue Aug 31 22:41:57 UTC 2021 upgrade: Image signature not present
Mods found: motorcomm_phy trb143 econet_phy quectel_embargo
Tue Aug 31 22:41:58 UTC 2021 upgrade: Commencing upgrade. Closing all shell sessions.
Connection to 192.168.2.1 closed by remote host.
Connection to 192.168.2.1 closed.
> ssh root@192.168.2.1
root@192.168.2.1's password:
BusyBox v1.34.1 (2021-08-31 22:20:08 UTC) built-in shell (ash)
____ _ ___ ____
| _ \ _ _| |_ / _ \/ ___|
| |_) | | | | __| | | \___ \
| _ <| |_| | |_| |_| |___) |
|_| \_\\__,_|\__|\___/|____/
Teltonika TRB1 series 2022
root@Teltonika-TRB140:~# cat /etc/version
TRB1_R_00.07.02.3
The only way to update the module is by adding the “force” parameter (-F):
> scp -O .\TRB1_R_00.07.05.4_WEBUI.bin root@192.168.2.1:/tmp
root@Teltonika-TRB140:~# sysupgrade -T -v /tmp/TRB1_R_00.07.05.4_WEBUI.bin
Tue Aug 31 22:56:12 UTC 2021 upgrade: TRB1_R_00.07.05.4
OK
OK
root@Teltonika-TRB140:~# sysupgrade -F -n -v /tmp/TRB1_R_00.07.05.4_WEBUI.bin
Tue Aug 31 22:57:16 UTC 2021 upgrade: Image signature not present
Tue Aug 31 22:57:17 UTC 2021 upgrade: Commencing upgrade. Closing all shell sessions.
BusyBox v1.34.1 (2023-11-07 13:33:48 UTC) built-in shell (ash)
____ _ ___ ____
Teltonika TRB1 series 2023
Device: TRB140
Kernel: 5.4.251
Firmware: TRB1_R_00.07.05.4
Build: d48a3687a6
Build date: 2023-11-07 15:44:58
Finally when using the test parameter (-T) the .bin file is manipulated in a way that the image signature gets corrupted. In our opinion this should not happen when using a test command (this can also be seen in the first example):
root@Teltonika-TRB140:~# sha256sum /tmp/TRB1_R_00.07.05.4_WEBUI.bin
457d5a683e775138ac3eb309a7f39ba3e6e748380d6aef503732de2302538769 /tmp/TRB1_R_00.07.05.4_WEBUI.bin
Tue Aug 31 22:52:54 UTC 2021 upgrade: TRB1_R_00.07.05.4
OK
OK
939b3cd72f8180c8bde40ca798e47d1616c9f8bea700f40592ccabe5a85e7455 /tmp/TRB1_R_00.07.05.4_WEBUI.bin
Tue Aug 31 22:53:14 UTC 2021 upgrade: Image signature not present
I would like to ask the following questions:
Why does the test command modify the image file?
What does the mods “motorcomm_phy trb143 econet_phy quectel_embargo” mean?
Why doesn’t the update work via webinterface or when using the sysupgrade command without the parameter -F?
Does the parameter -F can be used in this case? Manual tests of the module afterwards didn’t result in any problems.
FYI: The modules were not used before, but they have been in our warehouse for more than 1-2 years.
best regards,
Jürgen
