Hello, is there any information on the TRB140 PCB edge connector pins or on the J2 connector. I was hoping that these could be used for power and/or Ethernet.
Good afternoon,
Can you advise of your use case in the first instance?
Can you clarify, whether you are looking to only supply power via those pins, or connect other devices? Please expand.
Arturas
Hello Arturas,
We use the TRB140 to allow our customers to send SMS notifications to their customers. We use 1 device per customer.
I would like to create a PCB that would me to mount multiple devices and supply power using the least amount of space.
I know that I can use POE but I don’t need the ethernet connection as I connect remotely via a wireguard vpn
Keith
I have queried this information from our RnD team. I will advise, as soon as they respond.
Thank you for your patience.
Arturas
I would also be interested in having a reference for an adapter that
fits the connector on the right.
Regards.
Our RnD departament has advised me, that there are no power input on J2 and edge connectors.
We do not offer an adapter for such use case.
Arturas
