when i try to update the firmware of a device (in my case a TRB255) via RMS ,the process is painfully slow and it timeouts several times. Last time it took an hour of tries to update a single device.
I tried the update directly from the server and from a file uploaded to RMS.
Am i doing something wrong? There’s some parameter to set which maybe i missed?
The issue is most likely caused by a poor internet connection. Could you please share a screenshot of the WebUI from the Status → Network → Mobile page, so I can review the signal parameters?
Thank you for providing the details about your router. Based on the network information, it appears that the slow firmware update and timeouts you’re experiencing are expected behavior given the current connection.
Since your device is operating on a Cat-M1 network, which supports download speeds of up to 1 Mbps and operates on a narrow 1.4 MHz spectrum, firmware updates can take longer compared to other higher-bandwidth networks.
Additionally, the signal metrics you provided indicate that while the signal quality is decent, the overall signal strength and interference may further reduce effective data throughput.
