Thank you for your feedback.
I’ve just found the cause of the error.
In fact the error was linked to the difference in clocks between the server and the client.
After synchronizing the two clocks it worked.
If anyone else has this problem:
- Please check the firmware version between client and server
- Check that client and server have the same clock.
In this example, we have one client and one server. Is it possible to have two clients and one server? So that the two clients can talk to each other via the server in the same LAN?
I’ve currently set up this configuration with two clients connecting to the server, but I’m noticing regular disconnections.
