The issue with our RUT950 about the Operator Time Sync issue. We use a private APN with no internet connection, so we rely on the operator time sync function. It simply does not work on 7.6.3.
Try updating to newest available FW version (7.6.18)
Hello @m.basiouny,
Could you please confirm whether the latest available firmware has resolved your issue?
Hello @Marija ,
I have tested most of the firmware versions, including the latest one, but the issue still persists.
Thanks,
Try executing AT command: AT+CCLK? (either in CLI or in WebUI in Troubleshoot page Modem debug section).
To check if operator returns correct time.
It’s an M2M SIM card without internet access.
Thank you.
You can manually set the time via the WebUI by navigating to System → Administration → Date & Time → General.
Additionally, if you have a local NTP server, you can configure it in System → Administration → Date & Time → NTP.
Please let me know if this works for you or if you need any further assistance.
