The 'phantom' framed zone
OK, I’ve had this a couple of times …
I’ve factory reset, installed firmware and manually configured my settings. After reviewing the config. there is NO Firewall Zone named ‘framed’ but some time later, it magically appears but doesn’t have any ‘covered network’.
What could explain this mystical appearance from nowhere and what it is being used for?
‘Framed Routing’ has always been the default ‘off’ for both mob1s1a1 and mob1s2a1.
The ‘Framed’ zone appears when you enable Framed Routing in the mobile WAN settings.
Hi Marija,
‘Framed Routing’ has always been the default ‘off’ for both mob1s1a1 and mob1s2a1 - it has never been enabled.
I use wireguard a lot but I can’t think of any reason why it would turn on framed routing.
Thanks,
Mike
Apologies for the confusion. The ‘Framed Zone’ can appear when changes are made to the mobile interface, but it remains inactive until Framed Routing is enabled.
