Teltonika RUTX50 with WAN as primary internet source and 4G LTE as fallback
Understand the RUTX50 is primarily an LTE based router, could you use one in the home with VDSL/fibre modem connected on WAN as primary internet source, with 4G sim card as failover. If so, will the Teltonika switch back to WAN as and when it becomes available again after a drop in connection. End goal is to have a stable router with equally stable and strong 4G signal, maybe even with a view to using 4G/5G only going forward.
Yes, this can be done using the RUTX50’s Failover functionality, which can be configured in Network → Failover. To set it up, assign the WAN (wired connection) as the primary interface and the 4G SIM (mob1s1a1) as the secondary. Ensure the WAN interface has a higher priority (metric 1) while the mobile interface is set with a lower priority. Once configured, the router will automatically switch to the mobile connection if the WAN goes down, and it will switch back to the primary WAN when it becomes available again…
For more detailed information on configuring failover on the RUTX50, you can refer to this article: RUTX50 Failover.
If you need further assistance or have any additional questions, feel free to reach out.
Many thanks. I got it.
Edited by slope game 1 day ago
You’re welcome! Glad to hear that.
Feel free to reach out if you have additional questions or need assistance.
