Teltonika RUT240 and IGMP protocol version 2
Hello, I have your router RUT240 and solar equipment (DC/AC inverters and Energy Meter) connected to it through network switch. Data transmission between these devices works with multicasts and equipment manufacturer (SMA) states that “For the correct function, all network devices used must support the IGMP protocol, minimum required version 2 (IGMP V2).”
So my question is - does RUT240 support IGMP V2 and multicasts, and if it does - do I have to configure some specific settings in the router for everything to work?
Thank you in advance and kind regards!
I can reply to myself and anyone asking the same question - everything works fine “out of the box” without configuring anything on the router itself.
Hello @kjurec,
Could you please confirm whether the issue has been resolved, or if you still require assistance?
Hello, I can confirm that issue has been resolved.
Thank you for confirming that!
Please feel free to reach out on the forum if you need assistance with anything else.
