Hello everyone.
I have a RUTC50 and as WAN there is a single sim from the operator TIM Italy.
When I access via the “Teltonika RMS” app or via the web interface rms.teltonika-networks.com I am shown the IP address of the connection that does not correspond to the real public IP address. For example, on RMS the IP 10.72.52.54 is displayed, while if I connect via a device (lan or wifi) directly to the RUTC50, the real public IP address (dynamic in my case) of my operator is 217.201.248.208. I understand that the NAT masks the IP, but I do not understand why the RUTC50 displays this private IP address instead of the public one.
Through the RMS interface I should be able to display the real public IP.
At the moment, if I can’t connect directly via lan or wifi to the RUTC50 network, I have no way of knowing remotely what the real assigned public IP is. Is there a way to solve this problem?
Thank you in advance
