Could you please clarify whether the certificates you are trying to generate will be used for OpenVPN? This will help ensure that the guidance provided is aligned with your intended use case.
Additionally, you may find the following thread helpful, as it contains relevant information regarding OpenVPN client certificates when key material is already available:
