Currently I have a script that runs the speedtest command on my teltonika rutx12, the only problem is that after I run the command it prompts me with this:
This speedtest can use up a lot of internet data. Do you want to continue?(y/n)
Is there any way I can bypass this prompt with a flag or some other input?
The idea is to write the results to a file and then read the file later in the script
