Task Manager - Web Filtering
Having issue where my task is pushing to devices successfully and i can see the list of blocked websites in the webui for each device
however having an issue where they just disappear “randomnly” and then i have then repush the task again to the devices
ive only noticed this since doing bi weekly checks on the data usage in the last month so not sure how long it has been going off for
as it has been working as ive seen a massive cut back in data usage in our data pool
stuck in loop and not sure what is causing them to be deleted from the devices
Any ideas on this?
Checked the units again and the web filtering list has once again dropped off ?
Could you please provide the device model you are using and the firmware version currently installed on it?
Additionally, if I understand correctly, the issue is that some of the Site Blocking rules you created in Services → Web Filter → Site Blocking disappear unexpectedly. Could you please confirm this?
Looking forward to your response.
