I have the Rutx50 with the latest firmware. I would like to connect a wireless socket the Tapo p115 to the router, but the plug does not want to connect. I also paired a Tapo cam C110, but it works flawlessly. Hopefully someone has a solution.
While I can’t test it directly, I found some information that might help you integrate your Tapo devices with Home Assistant.
- First, ensure that the devices are integrated into the Tapo app and connected to the same Wi-Fi network as the device running Home Assistant.
- In Home Assistant, use the Tapo integration and enter your Tapo app credentials along with the IP address of your device.
For further assistance, you can refer to this link: What to do if you can’t control your Tapo devices.
