TAP200 reboot in loop after upgrade to R_00.07.16.3
After an upgrade to R_00.07.16.3, my TAP200 doesn’t want to boot anymore.
After power-on:
  1. status led is on, port leds are on for a few seconds.
  2. then port leds are off, and status led blink.
  3. after some time, loop to 1) (the device may be rebooting)
Already tried a factory reset without success. Can I do something else, other than returning the device (or throwing it away) ?
Thanks,
f the factory reset didn’t help, the bootloader menu is a special access point (AP) state used as a recovery tool when the device becomes inaccessible, even after a factory reset. It allows you to upgrade the AP’s firmware or bootloader version.
You can find the instructions here:TAP200 Device Recovery Options - Teltonika Networks Wiki
Please let me know how it goes.
Thanks for the instructions. I followed them, successfully retrieved the device under TAP200_R_00.07.15.4.
Then tried to upgrade to TAP200_R_00.07.16.3, same problem, downgrading again, and I’ll stay with TAP200_R_00.07.15.4.
Few notes on the tap200 recover wiki page:
  • there’s no switch plug, it’s a poe device, so press reset, then plug ethernet cable.
  • default ip (when not in bootloader mode) is 192.168.1.3, yes, but take any ip given by a dhcp server if any.
If I understand correctly, the issue does not persist on firmware version 7.15.4?
Yes, it works on 7.15.4
Thank you for confirming.
I’ve sent you a form to fill out. Once it’s completed, I will contact you privately. For the ticket ID, please use “14883”.
The issue has been resolved with firmware version 7.19.1.
