How does an infrastructure of TAP200 be setup? Each device individually or do you plan to use a SDN (Software Defined Network) solution (i.e. “OpenWISP”) ?
Thanks for your contribution.
Good afternoon,
Each TAP200 can be configured individually via its web user interface.
The process includes mounting the device, connecting power and Ethernet (PoE), and then logging into the device locally for setup.
We offer our own Remote Management System (RMS) for centralized monitoring, configuration, and updates. It is designed to streamline management for multiple devices from a single dashboard, supporting remote configuration, monitoring, and firmware updates for TAP200 devices.
You can have a read on the system’s functionality, how to add device. RMS Devices - Teltonika Networks Wiki
