Iβm running into a routing issue with Tailscale on a Teltonika RUTX11 router after upgrading to firmware recently. The setup worked perfectly on pervious firmware revisions, but now fails to route traffic correctly.
Setup Overview:
Tailscale installed through package manager.
Advertised subnet:10.0.0.0/24
LAN subnet:192.168.0.0/24
iptables used to NAT traffic between Tailscale advertised subnet and LAN.
Symptoms:
Can access router from tailnet address, however cannot access through adverised subnet routing.
We apologize for any inconvenience this issue may have caused. I have forwarded it to our RnD team. If we need more information from you or once I have any updates, I will let you know.
For further troubleshooting we will need to review troubleshoot files from your devices. Since it contains sensitive information, I have sent you a form to fill out. Once completed, I will contact you privately regarding this issue. @JamesMartyn β please use β15277β as the ticket ID. @phgerin β please use β15277-2β as the ticket ID.
The fix for the Tailscale subnet routing issue will be included in the upcoming 7.17.2 firmware release. Unfortunately, I donβt have an exact release date, but the firmware should be available soon.
My only other query that also kind of relates to this is will the Tailscale package be updated? It currently sits at v1.70 and Tailscale is up to v1.86?
