Tailscale on RUT 956
I would be very grateful if some expert help us
I have (several) RUT956, 07.11.3, with USB expansion enabled with a USB thumbdrive, now i want to install and try Tailscale VPN, is there a way to force install the package via CLI considering it isn´t available via package manager?
Hi…
Did look at this url?
https://wiki.teltonika-networks.com/view/Tailscale_Configuration_Example
I believe, it will be a start point.
Ops… I found a warning…
" The Tailscale VPN package is compatible exclusively with TRB1, TRB5, RUTX, and RUTM series devices. This is because Tailscale demands a larger amount of flash space, which surpasses the capacity available on our other devices. "
but… also found…
This post talk about tailscale supported by RUT956.
Yep, this is why i expanded flash memory with the USB drive
But at the same time i can´t find the package neither via package manager or downloadable on wiki, i tried one of the RUtx model, but was rejected by model
Thank you Marcelo, i appreciate your answer
I can see tailscale as package option for RUX12 ( RUTX_R_00.07.11.3 ) device:
https://wiki.teltonika-networks.com/view/RUTX12_Package_Downloads
https://opkg.teltonika-networks.com/ac70e03c5f8c22111eedc6da5d343058fdb43d26946a79c638abea4807756c34/wiki/tailscale.tar.gz
BUT
Cannot have this package for RUT956.
https://wiki.teltonika-networks.com/view/RUT956_Package_Downloads
Hello @rodrigobarrera ,
Unfortunately, the RUT956 does not support Tailscale. As Marcelo mentioned, the Tailscale VPN package is compatible exclusively with the TRB1, TRB5, RUTX, and RUTM series devices.
