Syntax changes RUTX08 07.12.3 -> 07.13.4 OpenVPN
Hi Teltonika team,
we have many RUTX08 around the world and manage the I/O’s with a script.
In 07.13.4 is a syntax change (again), with 07.12.3 we can detect the OpenVPN by the name:
ifconfig | grep -q ‘VPNName
now it’s replaced by the “interface”:
ifconfig | grep -q ‘tun_
Also enable and disable OpenVPN was before possible with:
uci set openvpn.VPNNAME.enable=‘0’
now the syntax of the setting is:
uci set openvpn.inst1.enable=‘0’
Is there a better way to script this upgrade resistant?
Thanks.
Yes, use API it shouldn’t change between versions. https://developers.teltonika-networks.com/
Hello @itsam,
Could you please confirm whether your issue has been resolved or if you still require any assistance?
Hi @Marija ,
still more questions than answers at the moment :slight_smile:
Unfortunately the examples [1] don’t show how to script it local on the device as /bin/sh script.
I need the following:
read input
if yes connect openvpn and enable output (high)
else disconnect openvpn and disable output (low)
I can use the api local in the script without authentication, right?
[1] https://developers.teltonika-networks.com/tutorials/
It can be called locally without authentication by using /sbin/api
Hello @Marija ,
do you have an example for me?
  • read state of OpenVPN connection
  • enable / disable OpenVPN connection
  • read digital input
  • enable / disable digital output
I try to replace our actual bash script with the new api…
Hello @itsam,
Here are some API examples you can use in CLI and in your custom script:
  • To read the OpenVPN connection state, use api get /openvpn/status
    More info: OpenVPN GET status
  • To disable the OpenVPN connection, use: api put /openvpn/config '{"data": [{"id": "inst1", "enable": "0"}]}'
    To enable it, use: api put /openvpn/config '{"data": [{"id": "inst1", "enable": "1"}]}'
    More info: OpenVPN PUT config
  • To read Input/Output status, use: api get /io/status
    More info: Input/Output GET status
  • To enable a digital output, use: api post /io/dout1/actions/change_state '{"data": {"value": "1"}}'
    To disable it, use: api post /io/dout1/actions/change_state '{"data": {"value": "0"}}'
    More info: Input/Output POST change_state
Thank you @Marija for the examples!
How can I use the json output in my bash script?
Is there any tool to get this values in variables?
For example, how to test the output of api get /io/status [...?...]?
if [ "$iostatus" == "0" ] ; then
else
echo "already enabled"
fi
(We don’t like to install additional add-ons, must be working with the basic RUTX08 firmware / commands).
Hello @itsam,
This is a simple example of the script which checks if OpenVPN disabled, and if it does, then it will enable it using API:
status=$(api get /openvpn/status | grep -o '"status":"[0-9]*"' | grep -o '[0-9]*')
if [ "$status" = "4" ]; then
  • Status 4 means the VPN instance is disconnected.
  • Status 2 means the VPN instance is connected.
