Support for IPv6 L2TP tunnel endpoint on RUTX50
Hi, as far as I can tell, support for an IPv6 tunnel endpoint when configuring an L2TPv2 client is missing. I can configure via the GUI with an IPv6 address, but cannot connect.
I believe xl2tpd does not support IPv6 tunnel addresses, which I think is the cause of the problem.
Are there any plans to support this capability in future, or am I doing something wrong?
I’ve inquired about this with our R&D team and will come back to you once I have an answer.
Hi again, @jagsta,
I’ve received an answer, and it seems that L2TP over IPv6 support is expected to be implemented with the 7.14 FW release.
That’s great news, thank you for the quick reply!
