Still Problems with RUT200 Updates
Good morning, unfortunately, following your advice we have not yet solved the problem. We have downloaded the latest firmware version and downloaded the relayd config from the package manager but nothing works. In the WAN interface the word “inactive” remains even if our PLC or electronic device configured as usual with the same network is actually connected. Only firmware 7.12.3 remains functional.
How can we solve this problem? I can’t make the sign of the cross every time.
Thanks.
Good morning,
Firstly, to assist you more effectively, could you please clarify your intended setup in a bit more detail? Specifically, what is the end goal you’re trying to achieve? In short, wireless relay (relayd) mode bridges the WAN interface with the LAN on Layer 2, essentially extending the upstream network through your device. Are you aiming for your PLC or other device to be reachable through the WAN?
Also, to understand your setup better, a simple topology with IP addresses would be helpful and appreciated.
If possible, please also provide screenshots of your current configuration, particularly where the changes were made.
Additionally, for your reference, there are a few Relayd configuration examples and guides available on our wiki that might offer some helpful insights:
Looking forward to your reply.
Good morning, basically the application is this: use the RUT200 router as a bridge between the company WiFi network and a PLC connected to the WAN port with the same network type, so as to reach the connected PLC from the technical office.
So by asking your assistance we configured the router in Client mode and using the relayd config it is possible to reach the IP address of the PLC via the company network.
The main problem is that with each firmware update the configuration is lost. Reconfiguring the module as before does not work anymore, I can no longer reach the device. At this point i downgrade to firmware 7.12.3 and everything works again.
Why?
