Static IP addresss for my router
Does the IP address of my RUT241 change when it is unplugged and plugged in again? How can I set a steady IP for my router to prevent disconnection in my IoT sensors by switching on and off the router?
Do you mean IP of the LAN or WAN? You can fix the LAN IP yourself as opposed to DHCP. The WAN can/will change and to fix that you would require to get a static IP which your ISP typically provides at a cost.
Could also use a public facing IP with DNS which won’t fix the IP but fixes the URL
