I’ve first sucessfully upgraded the firmware of my rut956 via SSH via sysupgrade commande line. to 07.05.04 release.
I’ve then tried to the the same for the backup-rut.tar.gz but it does not work as expected →
root@RUT956:/tmp# sysupgrade backup-RUT-2024-08-04.tar.gz
Tue Nov 7 13:47:29 UTC 2023 upgrade: Image signature not present
Tue Nov 7 13:47:30 UTC 2023 upgrade: Image metadata not present
Tue Nov 7 13:47:31 UTC 2023 upgrade: Use sysupgrade -F to override this check when downgrading or flashing to vendor firmware
Tue Nov 7 13:47:31 UTC 2023 upgrade: Firmware metadata not found
Tue Nov 7 13:47:32 UTC 2023 upgrade: Firmware metadata not found
sh: out of range
sh: out of range
sh: out of range
Image check failed.
root@RUT956:/tmp#
I’ve tried with -F and then my rut956 is not responding anymore …
It seems there might have been a misunderstanding in how you used the sysupgrade command, possibly without prior research.
Restoring the configuration from a backup file should be done using this command:
sysupgrade -r /tmp/backup-RUT-2024-08-04.tar.gz
The -F flag option should not be taken lightly. In the sysupgrade -h command, it’s stated that -F “Flash image/restore backup even if image checks fail, this is dangerous!”
Could you provide the exact command you executed that led to your device being bricked?
To activate the backup, the router needs to reboot. When backing up via sysupgrade, it must be done manually. However, using the WebUI automates this process.
To change the SIM PIN, you can use the following command:
gsmctl -A AT+CPWD="SC","1234","4321"
The first number should be your current PIN, and the second one should be your new PIN.
If you have any questions about RUTOS or any other Teltonika device functionality, don’t hesitate to search inside the community forum. Most likely, somebody has experienced a similar problem and found a solution to it.
