I dont get the unit of the speed that I am getting from the RUT955.
I found another topic here, that says “normally” it is in knots. But how to figure out the unit ?
Is it knots for 100%?
Thanks!
Thanks!
You could inspect/compare the NMEA sentence $GPRMC which includes speed over ground in knots or $GPVTG which includes speeds for both knots (unit N) and Km/Hr (unit K)
How to do this?
Can you explain it a bit more detailed please
Okay got it.
But from where do I know which nmea sentence is gpsctl -v using?
I doubt the gpsctl -v speed is determined directly from a NMEA sentence as the raw speed is possibly m/s? However comparing the gpsctl -v result to $GPVTG fields you will have speed in both knots & Km/hr to compare to.
Run the following command
ubus call gsm.modem0 info|grep gps
Result will look something like “gps_port”: “/dev/ttyUSB2”
Then based on the result above run the following which will stream NMEA sentences
cat /dev/ttyUSB2
Look for a sentence starting with $GPVTG, the numeric value before the field N is speed in knots, numeric value before the field K is speed in Km/hr. Compare those to result of gpsctl -v
Okay thanks! But is that different for every device or is the output of gpsctl -v the same for every device ?
This topic was automatically closed after 9 days. New replies are no longer allowed.
