Hi everyone,
I’m currently facing an issue with my RUT200 device running RUT2M_R_00.07.17.5, where I’m unable to access the router’s web interface (HTTP) anymore. The only available interface left for me is UBUS, and I’m trying to resolve the situation without needing a full reset or reinstall of the firmware.
Device Details:
Model: RUT200
Firmware Version: RUT2M_R_00.07.17.5 (OpenWRT-based)
Firmware Details: RUT2M_R (RouterOS firmware version)
Current Situation:
I cannot access the router through the HTTP web interface.
The only access available is via UBUS (I’m able to issue UBUS commands via
curl).
I’m considering the option of performing a soft flash or a soft reset to potentially restore access, but I’m not entirely sure if this is the correct approach.
Commands I’ve Tried:
Soft Reset Command (via UBUS):
curl -d "{\"jsonrpc\": \"2.0\", \"id\": 1, \"method\": \"call\", \"params\": [\"d58098644317f8947dda12c2869dba53\", \"system\", \"soft_reset\", {}]}" http://192.168.168.1/ubus -
Reboot Command (via UBUS):
curl -d "{\"jsonrpc\": \"2.0\", \"id\": 1, \"method\": \"call\", \"params\": [\"d58098644317f8947dda12c2869dba53\", \"vuci.system\", \"reboot\", {}]}" http://192.168.168.1/ubus
Issues:
Web Access: I cannot access the router through HTTP anymore. The web interface is unresponsive.
Soft Reset: The soft reset command doesn’t seem to have any effect on the system (or it doesn’t restore HTTP access).
Reboot Command: The reboot command immediately reboots the router without any confirmation or response, which complicates handling the error.
What I’m Considering:
Soft Flash: Could a soft flash help restore web access, or is there another UBUS command that might allow me to reset the router properly without completely wiping out all settings?
Firmware Recovery: Is there any specific UBUS command or method that I could try to restore HTTP access without needing to fully flash the device?
Environment:
Router Model: RUT200
OpenWRT Version: [Specify OpenWRT version if you know]
Access Method: Currently limited to UBUS (using
curlfor JSON-RPC calls).
