Is there a way to configure sender address to be lan-address when using openvpn? Currently snmptraps are sent from teltonika device(trb500) using ip-address of a vpn like 10.8.0.4(or what ever IP-is given from openvpn-server) instead of lan-address 192.168.2.1.
Thank you for reaching out and for your inquiry.
Your request is currently under review and analysis. Once the evaluation is complete, I will get back to you with further information, findings, or suggestions.
Thank you for your patience in the meantime.
Apologies for the delay in getting back to you.
I believe this might be achieved by adding a custom iptables postrouting rule. Could you try adding the following rule to your firewall via WebUI navigated to Network → Firewall → Custom Rules:
iptables -t nat -A POSTROUTING -o tun0 -p udp --dport 162 -j SNAT --to-source 192.168.2.1
no that didn’t change anything. Still see trap sender as trb500 vpn address, not lan address. Btw. theres also other issue, might be related to same thing, when I have device connected to trb500 lan and it has IP from lan-range, also it’s IP get written over with but is added to trap’s designated field. Is this related to snmp-engine in trb500 and it’s configuration?
Just to confirm, could you check what the actual openvpn interface name is (with ifconfig
command)? Then edit the iptables -o <vpn_interface>
option according to it.
Hi, yes, that was causing my problems.
