SMS utils not working
I asked for help a few weeks ago but then lost contact with the RUT (it’s in Guatemala and I only have remote access).
The problem I have is that it’s no longer responding to SMS messgaes
The firmware version is RUT9_R_00.07.06.6.
I send two messages from my phone requesting the status
You can see my number and an error in the log file
Failed to send SMS message to ‘+17744940387’
I’m attaching the log and some other config information as well as a screenshot.
The SMS messages used to work but I’m not sure why they don’t now.
Thanks for your help.
Mon Apr 8 16:40:24 2024 daemon.err rms_mqtt[12883]: Level: 16, Log: Client 1125472584 sending PINGREQ
Mon Apr 8 16:40:24 2024 daemon.err rms_mqtt[12883]: Level: 16, Log: Client 1125472584 received PINGRESP
Mon Apr 8 16:40:52 2024 daemon.err /usr/sbin/sms_utils: [1-1.4] Failed to send SMS message to ‘+17744940387’
Mon Apr 8 16:40:52 2024 daemon.info /usr/sbin/sms_utils: Removing SMS ‘0’ from memory
Mon Apr 8 16:40:57 2024 daemon.info urcd: Removing SMS ‘0’ from memory
Mon Apr 8 16:41:24 2024 daemon.err rms_mqtt[12883]: Level: 16, Log: Client 1125472584 sending PINGREQ
Mon Apr 8 16:41:24 2024 daemon.err rms_mqtt[12883]: Level: 16, Log: Client 1125472584 received PINGRESP
Mon Apr 8 16:42:23 2024 daemon.err rms_mqtt[12883]: Level: 16, Log: Client 1125472584 sending PINGREQ
Mon Apr 8 16:42:24 2024 daemon.err rms_mqtt[12883]: Level: 16, Log: Client 1125472584 received PINGRESP
Mon Apr 8 16:43:24 2024 daemon.err rms_mqtt[12883]: Level: 16, Log: Client 1125472584 received PUBLISH (d0, q0, r0, m0, ‘request/0/1125472584’, … (244 bytes))
Mon Apr 8 16:43:24 2024 daemon.err rms_mqtt[12883]: Received message: {
Mon Apr 8 16:43:24 2024 daemon.err rms_mqtt[12883]: “action”: 1,
Mon Apr 8 16:43:24 2024 daemon.err rms_mqtt[12883]: “data”: {
Mon Apr 8 16:43:24 2024 daemon.err rms_mqtt[12883]: “command”: “defaultData=$(/sbin/rms_json -v 18302644278662397633 -v 0 2> /dev/null);echo "$defaultData}"”
Mon Apr 8 16:43:24 2024 daemon.err rms_mqtt[12883]: },
Mon Apr 8 16:43:24 2024 daemon.err rms_mqtt[12883]: “device_id”: “1125472584”,
Mon Apr 8 16:43:24 2024 daemon.err rms_mqtt[12883]: “package_id”: “SmVbrX02IObtOh3RBQor61osYBwyMyZE”,
Mon Apr 8 16:43:24 2024 daemon.err rms_mqtt[12883]: “watcher”: 30
Mon Apr 8 16:43:24 2024 daemon.err rms_mqtt[12883]: Level: 16, Log: Client 1125472584 sending PINGREQ
Mon Apr 8 16:43:24 2024 daemon.err rms_mqtt[12883]: Level: 16, Log: Client 1125472584 received PINGRESP
Mon Apr 8 16:43:24 2024 daemon.err rms_mqtt[12883]: Executing request
Mon Apr 8 16:43:24 2024 daemon.err rms_mqtt[12883]: Received call action
Mon Apr 8 16:43:24 2024 daemon.err rms_mqtt[12883]: Executing command: defaultData=$(/sbin/rms_json -v 18302644278662397633 -v 0 2> /dev/null);echo “$defaultData}”
Mon Apr 8 16:43:24 2024 daemon.err rms_mqtt[12883]: Checking if call is finished
Mon Apr 8 16:43:25 2024 daemon.err rms_mqtt[12883]: Checking if call is finished
Mon Apr 8 16:43:25 2024 daemon.err rms_mqtt[12883]: Sending message: {“action”:1,“package_id”:“SmVbrX02IObtOh3RBQor61osYBwyMyZE”,“watcher”:30,“device_id”:“1125472584”,“data”:{“status”:0,“stdout”:“{"0":2,"1":"RUT9_R_00.07.06.6","7":"10849","8":"Mobile","9":"10.225.12.46","89":{"1-1.4":{"2":"sim2","15":"Inserted","16":"OK","18":"Registered, home","19":"-66","20":"Claro","21":"70401","22":"Connected","23":"LTE","24":"580","25":"10603","26":"10.225.12.46","27":"14532802600","28":"20204806325","40":"N/A","41":"N/A","42":"-105","43":"-3","44":"-18","29":"1152277","30":"704","31":"01","32":"4471","33":"8950201023047728842F","34":["1963273","2462554"],"35":["1963273","2462554"],"36":["252664082","2462554"],"37":["1382383","8967865"],"38":["1382383","8967865"],"39":["531201303","8967865"],"90":"primary"}}}}\n”}}
Mon Apr 8 16:43:25 2024 daemon.err rms_mqtt[12883]: Level: 16, Log: Client 1125472584 sending PUBLISH (d0, q2, r0, m44, ‘response/0/1125472584’, … (903 bytes))
Mon Apr 8 16:43:25 2024 daemon.err rms_mqtt[12883]: Level: 16, Log: Client 1125472584 received PUBREC (Mid: 44)
Mon Apr 8 16:43:25 2024 daemon.err rms_mqtt[12883]: Level: 16, Log: Client 1125472584 sending PUBREL (m44)
Mon Apr 8 16:43:26 2024 daemon.err rms_mqtt[12883]: Level: 16, Log: Client 1125472584 received PUBCOMP (Mid: 44, RC:0)
Mon Apr 8 16:44:26 2024 daemon.err rms_mqtt[12883]: Level: 16, Log: Client 1125472584 sending PINGREQ
Mon Apr 8 16:44:26 2024 daemon.err rms_mqtt[12883]: Level: 16, Log: Client 1125472584 received PINGRESP
Mon Apr 8 16:45:26 2024 daemon.err rms_mqtt[12883]: Level: 16, Log: Client 1125472584 sending PINGREQ
Mon Apr 8 16:45:26 2024 daemon.err rms_mqtt[12883]: Level: 16, Log: Client 1125472584 received PINGRESP
Mon Apr 8 16:46:26 2024 daemon.err rms_mqtt[12883]: Level: 16, Log: Client 1125472584 sending PINGREQ
Mon Apr 8 16:46:26 2024 daemon.err rms_mqtt[12883]: Level: 16, Log: Client 1125472584 received PINGRESP
Mon Apr 8 16:46:41 2024 daemon.notice netifd: mob1s2a1_4 (11700): udhcpc: broadcasting renew
Mon Apr 8 16:46:41 2024 daemon.notice netifd: mob1s2a1_4 (11700): udhcpc: lease of 10.225.12.46 obtained from 10.225.12.45, lease time 7200
Mon Apr 8 16:46:57 2024 kern.notice kernel: SMS received from: +17744940387 (internal modem)
Mon Apr 8 16:47:26 2024 daemon.err rms_mqtt[12883]: Level: 16, Log: Client 1125472584 sending PINGREQ
Mon Apr 8 16:47:26 2024 daemon.err rms_mqtt[12883]: Level: 16, Log: Client 1125472584 received PINGRESP
config rule
option action ‘reboot’
option smstext ‘reboot’
option authorization ‘password’
option allowed_phone ‘all’
option status_sms ‘1’
option message ‘Router name - %rn; WAN IP - %wi; Data Connection state - %cs; Connection type - %ct; Signal Strength - %ss; New FW available - %fs;’
option to_other_phone ‘0’
option enabled ‘1’
config rule
option action ‘send_status’
option smstext ‘status’
option to_number ‘+17744940387’
option to_other_phone ‘1’
option enabled ‘1’
config rule
option smstext ‘iostatus’
option message ‘DIN - %g3, Isolated DIN - %g6, 4Pin DIN - %g2, Analog input - %g1V, DOUT OC - %g5, Relay DOUT - %g7, 4Pin DOUT - %g4’
option enabled ‘1’
config rule
option action ‘io_set’
option smstext ‘ioset’
option io ‘dout1’
option value ‘on’
option enabled ‘1’
config rule
option action ‘wifi’
option value ‘on’
option smstext ‘wifion’
option write_wifi ‘1’
option enabled ‘1’
config rule
option value ‘off’
option smstext ‘wifioff’
option enabled ‘1’
config rule
option action ‘mobile’
option value ‘on’
option smstext ‘mobileon’
option write_mobile ‘1’
option enabled ‘1’
config rule
option value ‘off’
option smstext ‘mobileoff’
option enabled ‘1’
config rule
option action ‘vpn’
option value ‘on’
option smstext ‘vpnon’
option enabled ‘1’
config rule
option action ‘vpn’
option value ‘off’
option smstext ‘vpnoff’
option enabled ‘1’
config rule
option action ‘vpnstatus’
option smstext ‘vpnstatus’
option enabled ‘1’
config rule
option action ‘change_mobile_settings’
option smstext ‘cellular’
option simcard ‘1’
option enabled ‘1’
config rule
option action ‘list_of_profile’
option smstext ‘profdisp’
option enabled ‘1’
config rule
option action ‘change_profile’
option smstext ‘pr’
option enabled ‘1’
config rule
option action ‘ssh_access’
option smstext ‘sshon’
option ssh_access_enabled ‘1’
option ssh_access_remote ‘1’
option enabled ‘1’
config rule
option smstext ‘sshoff’
option ssh_access_enabled ‘0’
option ssh_access_remote ‘0’
option enabled ‘1’
config rule
option action ‘web_access’
option smstext ‘webon’
option web_access_enabled ‘1’
option webs_access_enabled ‘1’
option web_access_http ‘1’
option web_access_https ‘1’
option enabled ‘1’
config rule
option smstext ‘weboff’
option web_access_enabled ‘0’
option webs_access_enabled ‘0’
option web_access_http ‘0’
option web_access_https ‘0’
option enabled ‘1’
config rule
option action ‘firstboot’
option smstext ‘restore’
option enabled ‘1’
config rule
option action ‘switch_sim’
option smstext ‘switch_sim’
option enabled ‘1’
config rule
option action ‘gps_coordinates’
option smstext ‘gps’
option enabled ‘1’
config rule
option action ‘gps’
option value ‘off’
option smstext ‘gps_off’
option enabled ‘1’
config rule
option action ‘gps’
option value ‘on’
option smstext ‘gps_on’
option enabled ‘1’
config rule
option action ‘fw_upgrade’
option smstext ‘fw_upgrade’
option enabled ‘1’
config rule
option action ‘rms_status’
option smstext ‘rms_status’
option enabled ‘1’
config rule
option action ‘rms_connect’
option smstext ‘rms_connect’
option enabled ‘1’
config rule
option action ‘rms_action’
option value ‘on’
option smstext ‘rms_on’
option enabled ‘1’
config rule
option value ‘off’
option smstext ‘rms_off’
option enabled ‘1’
config rule
option action ‘monitoring_status’
option smstext ‘monitoring_status’
option enabled ‘1’
config rule
option action ‘uci’
option smstext ‘uci’
option enabled ‘1’
config rule
option action ‘more’
option smstext ‘more’
option enabled ‘1’
config rule
option action ‘userdefaults’
option smstext ‘userdefaults’
option enabled ‘1’
config rule
option action ‘wol’
option mac ‘c4:00:ad:98:7b:8e’
option smstext ‘WOL-A0’
option enabled ‘1’
config rule
option action ‘wol’
option mac ‘c4:00:ad:98:7b:8f’
option smstext ‘WOL-A1’
option enabled ‘1’
config rule
option smstext ‘gpsdate’
option action ‘exec’
option script ‘/etc/vuci-uploads/sms_utils.cfg2492bd.sh’
option enabled ‘1’
config rule
option smstext ‘WOL-C0’
option action ‘wol’
option mac ‘c4:00:ad:98:7b:03’
option enabled ‘1’
config rule
option smstext ‘WOL-C1’
option action ‘wol’
option mac ‘c4:00:ad:98:7b:04’
option enabled ‘1’
config rule
option smstext ‘suspend’
option script ‘/etc/vuci-uploads/sms_utils.cfg2692bd.sh’
option enabled ‘1’
config rule
option smstext ‘dropboxstatus’
option script ‘/etc/vuci-uploads/sms_utils.cfg2792bd.sh’
option enabled ‘1’
config rule
option smstext ‘dropboxstart’
option script ‘/etc/vuci-uploads/sms_utils.cfg2892bd.sh’
option enabled ‘1’
config rule
option smstext ‘dropboxstop’
option script ‘/etc/vuci-uploads/sms_utils.cfg2992bd.sh’
option enabled ‘1’
config rule
option smstext ‘trigger’
option io ‘dout2’
option value ‘off’
option write_config ‘0’
option seconds ‘1’
option timeout ‘1’
option enabled ‘1’
config rule
option smstext ‘triggeroff’
option value ‘on’
option timeout ‘0’
option io ‘dout2’
option write_config ‘1’
option enabled ‘1’
config rule
option smstext ‘nordvpnmeshoff’
option script ‘/etc/vuci-uploads/sms_utils.cfg2c92bd.sh’
option enabled ‘1’
config rule
option smstext ‘nordvpnmeshon’
option script ‘/etc/vuci-uploads/sms_utils.cfg2d92bd.sh’
option enabled ‘1’
config rule
option smstext ‘nordvpnlogin’
option script ‘/etc/vuci-uploads/sms_utils.cfg2e92bd.sh’
option enabled ‘1’
config rule
option smstext ‘nordvpnlogout’
option script ‘/etc/vuci-uploads/sms_utils.cfg2f92bd.sh’
option enabled ‘1’
config rule
option smstext ‘nordvpnstatus’
option script ‘/etc/vuci-uploads/sms_utils.cfg3092bd.sh’
option enabled ‘1’
config rule
option smstext ‘killallssh’
option script ‘/etc/vuci-uploads/sms_utils.cfg3192bd.sh’
option enabled ‘1’
config rule
option smstext ‘powerbutton’
option seconds ‘1’
option timeout ‘1’
option io ‘relay0’
option value ‘off’
option enabled ‘1’
config rule
option smstext ‘H3restart’
option script ‘/etc/vuci-uploads/sms_utils.cfg3392bd.sh’
option enabled ‘1’
  • Verify your SMS authorization credentials. Check if your password (or serial/admin password) is included in the SMS and ensure it’s correctly written.
  • It’s possible that your device’s memory is full, preventing you from receiving SMS messages. If you have remote access to your RUT, check the available memory by navigating to Services → Mobile Utilities → Messages → Storage in the WebUI.
  • Test your SIM card on another device, such as a phone, to confirm its functionality. If you can’t send messages from another device, it’s possible that your mobile SIM card plan is exhausted, which may prevent the router from sending SMS messages.
  • Consider updating your device to the latest firmware version, RUT9_R_00.07.06.10. New firmware releases often include issue fixes and improvements that may resolve issues you’re experiencing.
Let me know how it goes!
