Rut901 - want to use the sms gateway to send sms from our system to customers… Seems very tempermental… i am unable to use the post/get form our software server connected on lan to Rut901. When I try to log into rut901 from device using lan ip , i get unable to access… from other devices on lan, I can log in… we are able to send sms from webui on Rut901.
From another device on lan, we cannot use post/get via web browser… Any ideas/help ?
Router doesnt seem to like changes and reboots - we have updated to latest firmware
Could you confirm if the issue is that some LAN connected devices can successfully send POST/GET requests to the RUT901’s SMS Gateway, while others cannot? Additionally, you mentioned being unable to access the WebUI from one specific device. If that’s the case, it’s possible the device’s IP address was temporarily blocked due to multiple failed login attempts?
Also, have you attempted a factory reset of the RUT901 to see if the POST/GET request issue persists after reconfiguration?
Kindly let me know if the issue still persists or you have additional questions.
