I have a RUT360 and am very happy with it other than with its wifi performance. I am looking at buying a couple more if I can get this issue solved.
I have it connected over 4G but I have also experimented with using it as a repeater.
Over ethernet I have been getting 50mbps download. But when I connect over wifi the speeds drop to around 6mbps.
I tried doing a speed test to my colleague, with us both connected over wifi so I know it’s definitely a wifi issue.
I have attached a troubleshoot file in case it helps.
I’ve just reviewed your troubleshooting file and even attempted to recreate your WiFi setup. Interestingly, I achieved nearly identical speeds over both LAN and WiFi. I have some suggestions for optimizing your WiFi speed:
Navigate to the router settings: Status → Wireless → Channel Analysis → Check the channel congestion rating. Opt for a few channels with the least congestion for testing purposes.
Proceed to Network → Wireless → Radio. Ensure that the “Transmit power” is set to 100%, the “Operating frequency width” is configured to “20 MHz,” and experiment with the least congested channels.
Give these steps a try and share your findings. Once you do, we can further investigate the issue.
