I’m using a RUTX11 and/or RUTX10 inside a mobile system to connect to a WiFi network (client mode a.k.a. sta mode) which has both 2.4Ghz and 5Ghz radios. The WiFi network SSID and password are the same for both radios (new feature in latest firmware - but not sure if this is full band-steering?). As the plan is to have many such mobile systems I need to be able to have a centralized place to manage IP addresses to the router (RUTX) of the mobile systems. Therefor I have to use DHCP to get a reserved DHCP lease on the WiFi client (RUTX), e.g. IP-MAC binding.
We update the firmware to RUTX_R_00.07.06.10
which has support for both radios on a single wireless network and it supports wireless WAN. With this firmware it now uses a software managed MAC address (02:1E:42:…:…:…) to connect to the network, which is ok and better for security. The problem is that this MAC is not stable, sometimes it picks the software managed MAC address for the 2.4Ghz radio and sometimes it picks the one from the 5Ghz radio. This means in my DHCP server I still have to specify both MACs and use two IP addresses, which is not what I want. We want to have a single IP for each mobile system.
Overwriting the MAC address of the Network - WAN - Wifi0 interface
would solve it but this field is ignored, and the software managed MACs are still forwarded though the DHCP server.
Is there a way to either an overwrite function for the MAC on the wifi0
or a feature to select which of the two radios should be used for the software managed MAC?
product: RUTX10 and RUTX11
firmware: RUTX_R_00.07.06.10
Elias
