Hello. I have an RUT955 router in the UK and am trying to connect with a Simbase SIM and am struggling to get it to work. I have set the APN to the right value (simbase) but it does not seem to connect. The SIM works on my iphone. What am I missing…?
First update you firmware to the latest version
https://wiki.teltonika-networks.com/view/RUT955_Firmware_Downloads
Checking the note … FW version RUT9_R_00.07.00 and above will not be supported on legacy-design (RUT955 x7Vxxx) devices … to see if it’s applicable to your particular device.
If no further forward after this, then I suspect that you’ll have to manually configure the correct APN,
