Sim Lock , what’s the pin?
Hi , I wanna know if in order to activate the sim lock I need to know the pin of the sim 1st. It’s my first time activating this option, I don’t wanna mess it up.
Picture for reference
Correct PIN code is required to enable or disable SIM card lock. Once SIM card lock is disabled you will not need to enter PIN code on any device to use SIM card.
Okay, thank you. What I’m currently searching for is that I want to lock to just that specific SIM card, is it possible? Thanks in advance
If I understand correctly, you would like to lock either SIM1 or SIM2 on your device (if it has two SIM slots). To do this, you can set the desired SIM as the default and then lock it under Network → Mobile → Utilities in the WebUI.
For more information, please refer to our wiki page: RUTX50 Mobile Utilities.
If I misunderstood something, please feel free to correct me and provide further details. Thank you!
Best regards.
Sorry I’ll give you more details. It’s a RUT200, I want to make sure if someone puts another sim on it, that this one doesn’t work, because it’s just supposed to use the one that I set… is there any way to achieve that? , maybe entering the pin - puk.
Thanks in advance
Thank you for the explanation.
Unfortunately, there are no built-in configuration settings to achieve that. However, you can consider creating a custom script that might help accomplish your goal.
Here are some resources to get you started with custom scripting:
