Hello
Is there a quick shortcut method via telnet or sms, that allows one to change between the failover methods on a RUT360?
You can disable or enable your failover interfaces via SMS by sending these messages to your RUT360:
uci set mmwan3.wan.enabled='0'
uci commit
For WAN interface, use ‘wan’, and for mobile interface, use ‘mob1s1a1’ or ‘mob1s2a1’.
To disable the interface, use ‘0’; to enable it, use ‘1’.
Hope this helps!
