Setup DHCP on Lan And Wifi
Hi I have been testing some options with the RT956 - RUT9M_R_00.07.08
I have it doing most of what I want but somehow in the process I seem to have lost the ability to have DHCP on wifi and Lan with devices able to communicate between themselves.
Can anyone point me to getting back to this without resetting my router?
S
To enable DHCP in the WebUI:
  1. Navigate to Network → LAN.
  2. Press “Edit” next to the LAN interface.
  3. Enable DHCPv4 and/or DHCPv6.
  4. Press “Save & Apply”.
Additionally, you can find DHCP settings in Network → DHCP.
Hope this helps!
Thanks for this. Is there a way to have one DHCP server for Lan and wifi. I have had to use 2 servers on the same range to give out address, but I can then not get to the Web GUI from a Lan connection.
Steve
To answer my own question. In the wireless settings I need to select Lan as the network, no other Lan network was needed.
S
It’s great to hear that you found the answer to your question on your own!
Please let me know if there is anything else I can assist you with regarding this topic.
