Setting up TRB245 monitoring via Modbus Gateway mode from a "white" IP
Hello, I have an energy meter connected to the TRB245 via the RS485 interface. The TRB245 has a SIM card with a static white IP. The TRB operates in the modbus gateway mode. I receive data from the meter via the LAN interface, and I can also control the meter via VPN (IPSeq). But I can’t configure the device to receive data via the VAN interface via IP. Please tell me the necessary settings.
Thank you.
