I am struggling to setup my RUTX14 as WIFI bridge (to an external WIFI network) and can’t find any up-to-(firmware)-date documentation. Here is a pdf document based on an old RUTX11 firmware with a step by step installation I am referring to: https://www.solwise.co.uk/downloads/files/TL-RUTX11-how-to-use-a-teltonika-rutx11-to-bridge-a-connection-on-2.4ghz-and-re-broadcast-on-5ghz.pdf.
My firmware (from January 2024) is: RUTX_R_00.07.06.3.
My step by step setup experience vs the www.solwise.co.uk recommendation:
Step 1
Navigate to NETWORK / WIRELESS and click on the SCAN button in the 2.4Ghz wireless network section. ###WORKS###
Step 2
Once the scan finishes, Click the JOIN NETWORK button that corresponds to the 2.4Ghz wireless network that you wish to bridge a connection to. ###WORKS###
Step 3
Next, type in the passphrase for that wireless network, ensure that ‘Name of the new network’ is ‘wwan’ and then click the SUBMIT button.###Q: Does it have to be “wwan”? My default option is “wifi1”.
Step 4
Then click the SAVE & APPLY button to confirm the configuration. ###WORKS###
Step 5
Next navigate to NETWORK / LAN and in the LAN SETTINGS section, click on the ‘Pencil’ icon.
###My one and only LAN interface is showing green status “up” and type: “Bridge”.###
Step 6
Scroll down to the bottom of this page to the RELAY CONFIGURATION section, enable it, make sure that the ‘Interface’ is using ‘wwan,’ and then click the SAVE & APPLY button to apply the configuration.
###My interface looks very different: No access to “RELAY CONFIGURATION” here, and instead:
General settings: Enable on/off, default: on, Name: Default: “lan”, protocol: “Static” and IPv4 address and net mask showing my router’s IP address.
Accessing RELAY CONFIGURATION settings in my case (latest firmware):
Network > Wireless > Relayd
My settings here: Enabled: ON, Interface: lan, Wireless interface: “wifi1”.
That’s it. None of my existing two WIFI networks have an internet connection.
No additional “wifi1” network is showing up.
Please help me to make this work. Thank you!
A presentation is attached hereto. Unfortunately not as PDF as this format is not accepted here. (???)
Instead I uploaded images.
