I’m trying to trigger an alarm via command through the RUT955 but haven’t been able to set it up properly on the portal. Has anyone done this? Should be a very simple task, I’d really appreciate some guidance.
Many thanks!
Many thanks!
Thank you for reaching us; could you please confirm if it is a Modbus alarm?
Thanks,
Mahmoud
Hi, thanks for replying.
No, it’s just a simple 12v alarm that is usually triggered with a remote.
Could you please provide information on the way you are using for connection and specify which alarm you are looking to trigger?
In general, I will provide you with a wiki article related to I/O alarms.
Thanks,
It’s an alarm like this.
I tried connecting its positive and negative into pins 2 and 7 but I could not find the right set up to send the signal to trigger the alarm.
Thanks.
Thank you for providing clarification. Could you kindly utilize pin5 and pin10?
Thanks,
Thank you for confirming. I will try this an update with the progress.
Just to clarify I shall be connecting the + and - from the alarm into pins 5 and 10 respectively, right?
kindly see the below photo.
Thanks,
Mahmoud
Many thanks for the diagram. I’ll update the thread once I’ve tried it!
