I’m working with Justin to setup VPN communications using an RUT241.
Thanks,
Josh
Thanks,
Josh
For troubleshooting purposes, we will require more sensitive information from your end, such as the troubleshoot file, which may contain passwords, public IP addresses, serial numbers, and such. To avoid leaking this information, we have sent you a form to fill out, which you will receive in your e-mail inbox that you have registered your account with in the forums. In the Ticket ID field of the form, please enter the ID of this thread, which is 17422.
Remote access to a PLC wasn’t working, turning on masquerading for the LAN zone solved the issues, since the PLC didn’t have a gateway set.
