Im trying to set password using
passwd -p ’ Plain text password ’ root
passwd -p 'Plain text password admin
still without a success.
It will be used to automate Zero Touch config software.
Simply use passwd <username> and you will be prompted to enter your new password for that user:
passwd admin
passwd root
You can echo your new password and pipe into passwd so that you dont have to enter the password manually after you execute the command. Since password needs to be retyped, you can do:
echo -e 'Tester123\nTester123' | passwd admin
This will set admin password to ‘Tester123’
Thanks, it works now
