Setting '5G Only' on Network Types - TRB500
Hi I’m trying to fix my TRB500 onto 5G only. Currently my only options are 4G/5G/3G, 4G/3G, 4G Only or 3G Only.
The current software version is 00.07.07.3
Any help or advise would be greatly appreciated.
It depends on your ISP if that is even possible.
You could try setting 5G to SA instead of NSA, but likely you will lose the connection.
Thanks for reaching out!
After 7.08 Firmware release we put the SA/NSA options for 5G.
You can find detailed information from here.
Please try upgrading the firmware and let me know about the result!
Caner
