Server refused connection, the device may be blocked or unidentified
I am having issues connecting to RMS on teltonika RUT-240, I didnt had this issue before after device was off for one month now I see this issue.
It is failing to connect to RMS with this
connection state: Failure (Server refused connection, the device may be blocked or unidentified)
I have credits allocated for management service and remote connect & vpn services for this unit.
Best
Chaitanya
can anyone support me on this, its quite urgent.
Hi chai,
Can you try to send an SMS command to the router to force RMS connectivity. Kindly follow this syntax. [device password] rms_connect. Recheck internet connectivity of router. If possible, try to remove the device in RMS and re-add it. Make sure to have a copy of device password, serial number, and LAN MAC Address.
Let me know if this helps.
I stumbled upon a similar problem. After multiple reboots due to power failures
(probably up to 50 in one day) suddenly the device (a RUT240) was
“temporarily blocked” in RMS.
After sending the SMS command “rms_off” and waiting for one day (and then
re-trying) nothing changed. In my post to the forum @anon65719490 suggested the
same as @Janmiguel.
So I copied the MAC address and the device serial number from the old RMS entry
(and of course I knew the password) and the deleted the device.
After deleting and re-adding the device and sending the SMS command “rms_on”
I just had to wait one or two minutes for the RUT240 to be green in RMS again.
AND I didn’t need a new credit because the old one was still active on the RUT!
So thanks to you support guys!
Timlapse Admin
