Server file errors in system log
I have uploaded a server file called dns2.rtf wit the following format:
192.168.0.1 rutc.lan
192.168.0.139 pi2.lan
192.168.0.117 pi3.lan
192.168.0.241 pi5.lan
in the system log I am getting the following errors:
763 Wed Apr 30 20:38:29 2025 daemon.err dnsmasq[4402]: bad option at line 1 of /etc/vuci-uploads/cbid.dhcp.general.serversfiledns2.rtf
764 Wed Apr 30 20:38:29 2025 daemon.err dnsmasq[4402]: bad option at line 2 of /etc/vuci-uploads/cbid.dhcp.general.serversfiledns2.rtf
765 Wed Apr 30 20:38:29 2025 daemon.err dnsmasq[4402]: bad option at line 3 of /etc/vuci-uploads/cbid.dhcp.general.serversfiledns2.rtf
766 Wed Apr 30 20:38:29 2025 daemon.err dnsmasq[4402]: bad option at line 4 of /etc/vuci-uploads/cbid.dhcp.general.serversfiledns2.rtf
To clarify a few points, could you please confirm where exactly you uploaded the dns2.rtf file?
For dnsmasq to properly read a custom hosts-style file like yours (with IP hostname pairs), it should either:
  • Be referenced in the /etc/dnsmasq.conf file using the line:
addn-hosts=/path/to/your/hosts/file
Or
  • Be added via the WebUI under Network → DNS → General Settings page, Advanced Settings tab** in the Additional servers file field.
Also, try specifying the DNS servers file in plain text format without any rich text formatting (RTF).
I uploaded it using the web UI and tried a plain text format too but it was still not working properly for me.
It now works but I abandoned the file option and added all my domains manually via the UI
