Serial Communication Script
Hello.
I have a device that has a custom protocol and it works with RS485. For now I am testing using a modbus device but im trying to send commands to the device then read the response. I am unable to find a way to send my serial command to the device. Here is my script:
#!/bin/bash
RS485_PORT=“/dev/ttyS1”
BAUD_RATE=9600
DATA_BITS=8
STOP_BITS=1
PARITY=“none”
TIMEOUT=5
stty -F $RS485_PORT $BAUD_RATE cs$DATA_BITS -cstopb -parenb -icanon -iexten -echo
send_byte() {
local byte=$1
printf “\x$(printf ‘%x’ $byte)” >> $RS485_PORT
MODBUS_REQUEST=“01 06 01 90 00 03 49 35”
echo “Sending Modbus request…”
for byte in $MODBUS_REQUEST; do
send_byte “0x$byte”
done
sleep 1
echo “Reading response from Modbus device…”
MODBUS_RESPONSE=$(dd if=$RS485_PORT bs=1 count=256 2>/dev/null | xxd -p -c 256)
if [ -n “$MODBUS_RESPONSE” ]; then
echo “Received Modbus response: $MODBUS_RESPONSE”
else
echo “No response received from Modbus device.”
fi
I know the MODBUS_RESPONSE command works because I tested that separately, but for the life of me I can’t send anything.
I managed to get it working. If anyone else is having this issue the solution was to leave the stty configuration and send a request using:
slave_address=01
function_code=03
start_register=0x0191
num_registers=0x0001
request=“${slave_address}$(printf “%02X” $function_code)$(printf “%04X” $start_register)$(printf “%04X” $num_registers)”
crc=$(crc16 “$request”)
request_with_crc=“$request$crc”
request_bytes=$(echo “$request_with_crc” | sed ‘s/…/\x&/g’)
echo -n -e “$request_bytes” > /dev/ttyS1
The crc16 is just a normal check sum function
