Send to server problems
I have two RUT956
One of them i setup long time ago and almost Every IO to HTTP is working.
I tryed to export the settings to upload to my newer RUT956, but the new will not accept the settings.
Now i try to start over and set it all up again so all of the in- & Outputs send there state to my server.
But the IO or GPS is not showing in the dropdown.
so i cant create it.
And they are on the same Firmware version.
Basic i want all data fron the RUT to be sendt to mu server, but i can’t find where to set it up.
I have tryed to Update the RUT to the latest Firmware again, but still not finding it.
I want to sent: Base, MNF, GSM, IO, GPS, SMS
Greetings Kodak,
Thank you for your question.
To export settings from one device and upload them to another, the following conditions must be met:
  • Both devices must be the same model.
  • Both devices must be running the same firmware version.
  • The product codes of both devices must match. You can check the product code by navigating to Status → System, where it is displayed under the “Device” section, as shown in the screenshot below:
Regarding your IO or GPS options not appearing in the dropdown menu, this may be resolved by installing the Advanced Data to Server Modules package from the Package Manager. To do this, navigate to System → Package Manager, type the package name in the search bar, and install it. Once the installation is complete, additional data options, including IO and GPS, should become available to send to the server.
Please let me know if this resolves the issue or if you need further assistance.
