Save / Load Services Set ups - Different product codes
Hi
Is there a way of saving and loading the services configuration for multiple RUT955s. The backup and restore will not work due to the different product codes,RUT955V03XXX and RUT955T03XXX . The services set up I would like to copy across are ‘Data to Server’ and ‘Modbus Serial Client’
In case if you only want to copy the Modbus configurations, you should be able to copy the relevant Modbus configuration files from /etc/config directory to your other RUT device. To copy and upload the files, you can use SCP or SFTP. For Windows machines, you can use an application such as WinSCP.
