Device: ALTOS-CAP700, firmware CAP7_R_00.07.23.6
Connection: Telekom.de, 5G (NSA), CG-NAT (WAN IP 192.0.0.2/32)
LAN bridge: eth0, eth1, usb0 (STP off, IGMP off)
WiFi SSID: bridged to the same “lan” network/zone as Ethernet
Issue:
a Samsung Smart TV connected via Ethernet cable to a LAN port on the CAP700 gets Smart Hub error 202 (cannot connect to Smart Hub services), while the exact same TV connected via WiFi to the same router/bridge works perfectly every time.
Troubleshooting already performed:
- verified cable integrity with a cable tester — OK
- verified TV gets correct IP/gateway/DNS (192.168.1.x, gateway/DNS 192.168.1.1)
- ruled out CG-NAT as the cause: tested TV on two different mobile hotspots (Telekom.de and o2.de via iPhone) — Smart Hub worked perfectly on both, despite both also being behind CG-NAT
- confirmed WiFi and Ethernet are bridged into the same “lan” network/zone (verified in Network > Wireless > SSID config, “Network” field = lan)
- connected a laptop to the exact same Ethernet port/cable: experienced partial connectivity issues (~30% of websites, including banking sites, failed to load), while ping (ICMP) and speed tests (nPerf) were fine - classic PMTU black hole symptom
- fixed the laptop issue completely by setting “Override MTU” = 1472 on the LAN interface (matching the WAN MTU, which was already set to 1472 due to a previously diagnosed MTU mismatch with Telekom.de’s 5G network)
- after this MTU fix, the laptop has 100% working connectivity on the same port/cable. However, the Samsung TV still intermittently fails with error 202 on the same Ethernet connection.
Additional observation:
- on the TV, Smart Hub test sometimes passes initially, then fails after a failed attempt to open a streaming app (Pilot WP), and stays failed until switching back to WiFi.
Questions:
1. Is there any known difference in how the WiFi radio interface vs. the physical Ethernet ports handle MTU/fragmentation within the same LAN bridge on the CAP700?
2. Is there a way to manually control Ethernet port speed/duplex (auto-negotiation) on this model? I could not find this option anywhere in the WebUI (checked LAN interface > More > Physical Settings).
3. Are there any known compatibility issues between CAP700 and Samsung Smart TVs over wired Ethernet specifically?
XynthCode
