its this able to set load balancing if i plug-in 2 sim card but not fail over.
customer has also below question.
if there are other model able to do so, please let me know the part number.
Requied:
Multi-SIm Router with LAN Port
at least 2 SIM can be load balancing
Able to use Singapore telco sim: Singtel/Starhub/M1
You can configure Load Balancing on the RUTX50 by following the instructions described on our wiki page.
Regarding SIM cards, as TeWe mentioned, the RUTX50 can only use one SIM card at a time, whereas the RUTX12 can use two SIM cards simultaneously. More information about the RUTX12 can be found on our website. In the ‘Ordering’ section, you can find the product code that will be suitable for your country.
