I am trying to follow your guide to install Zabbix agent on a RUTX50 but its failing with the below after the command opkg install zabbix-agentd
can you advise on this?
Also, is it possible i can SNMP or get the GPS coordinates from the RUTX50 into Zabbix?
Thanks in advance
Marija
3
For installing Zabbix, please refer to this post: Zabbix Agent on RUT240.
Regarding monitoring via Zabbix, please check our wiki page here: Monitoring via Zabbix, which should be helpful for you.
Let me know if you need any further assistance!
system
Closed
4
