Hello Marijus,
Thanks for this answer.
Please could you give me some more details regarding it ? As RUTX50 natively supports 12 V, I thought there would not be any problem just adding the right fuse. I needed, I’ll buy the automotive power supply, of course.
Thanks a lot
Hervé
Oh great, thanks So I guess there’s any problem doing this if the electrical connection is well done, of course
Do you have the RUTX50 too ? If so, did you put it in a small cabinet or outside ? I don’t know if it can be in a cabinet because it seems to heat when it works.
I don’t think there is any problem with it wired to a vehicle as their voltage range is quiet wide, 9: 50 VDC, reverse polarity protection, surge protection >51 VDC 10us max.
If you were concerned, you could purchase a UPS (Uninterrupted Power Supply)
Yes I have one also, I use it at home with two of us working from home and I also use it in the campervan.
I have it in a big cabinet, so it should be ok. I have this antenna on the camper.
One more question, sorry ! Is 1 Amp enough ? 12 V with 18 W max, so the fuse should be around 2 Amp, no ? Also, did you take a slow-blow fuse or a fast-acting fuse , I guess a slow one should be better because of the W variations, no ?
No bother, glad to help.
When you work it out, it comes in at 1.5/2.0 Amp fuse. I just went with a 1 Amp to be safer and it hasn’t blown yet. I’ve just used a standard automotive fuse, I’m hoping its ok to use it.
