I d’like to configure my router than in case of having Wifi client connected to Network and get access to Internet, router recognize it automatically and stop using mobile (4G/5G) access as Primary.
I tried to get it via Failover mechanism but seems as not working for me and always Mobile access is prioritized.
Second Question, can we configure it without additional configuration tasks so appearance of Operational Wifi will change routing (metric) sequence and immediately change a path how traffic reach e.g Internet. Obviously, loosing Wifi access we fallback to Mobile access (4G/5G).
I’m not quite sure, if I understood your issue correctly, but ordering failover interfaces in the Network → Failover → Multivan page in your desired order of priority should be all that you need to do. For example:
and configure new rule “wifi_first” to force wifi being first before mobile interfaces.
However, seems as the rule doesn’t accept wifi and always come to previous sequence:
First of all, make sure that after your router loses the Wi-Fi signal, it reconnects. If it doesn’t reconnect, there’s no interface to failover to, and it stays on the mobile connection.
Additionally, could you SSH/CLI into your device and provide the output of this command:
mwan3 status
This might help understand the status of the failover configuration.
From the image, it seems that no failover is configured. Could you configure failover again and run the command mwan3 status again? Additionally, don’t forget to save the failover configuration after configuring it. The save button is at the bottom of the page.
Hello Marijus,
Thank you, it was a hint, I need to switch interface to participate in failover. Now everything works as expected.
Second question. I 've configured VPN as OpenVPN client (NordVPN service). Can I able to configure such use cases ?
Specific destination (host or subnet) should be sent via VPN, rest traffic bypass VPN?
Specific Interface like LANx or create dedicated wireless SSID that if I connect here always trafffic should use VPN in order to reach any destination.
How to achieve it on Teltonika router RUTX50?
nkemot
